Activity Forums Apple Final Cut Pro Legacy Delay in Video Preview
  • Delay in Video Preview
    Posted by Joseph Wilkins on April 18, 2006 at 6:33 pm
    I experience a 15 frame or so delay in audio synch when previewing to an external monitor.
    Does anyone know how to fix this? It only happens when using the external monitor, not when I run the timeline without the preview.
    Cody Alberts replied 20 years, 5 months ago 2 Members · 4 Replies
  • Cody Alberts
    April 18, 2006 at 8:25 pm
    Try:
    -VIEW>AUDIO PLAYBACK
    It should match what you are using to output to your monitor. Usually “FireWire DV”. Or try “Audio Follows Video”.
    If that doesn’t work try:
    -SYSTEM SETTINGS>PLAYBACK CONTROL
    There is a “Frame Offset” box, by default it is set to 4 frames because of the latency in FireWire devices.
  • Cody Alberts
    April 18, 2006 at 8:26 pm
    Also,
    Where are you monitoring your audio from?
  • Joseph Wilkins
    April 19, 2006 at 1:31 pm
    I am using Built in Audio to hear the audio from my pro speakers that are hooked into my g5
  • Cody Alberts
    April 19, 2006 at 3:56 pm
    In order to hear your audio in sync, you have to route your audio from your source. I you are using Built in audio and monitoring externally, that is why you are having the delay.
    Do you have a way to route your speakers from your external monitor?
