Activity › Forums › Apple Final Cut Pro › Delay in pressing play and start of material on TL
Posted by Sascha Engel on February 26, 2015 at 10:13 amHi,
I have following problems: With certain Time Lines, I have following issue: the time in between pressing space bar/Play and the footage actually playing is up to 2 seconds. Put that only applies to certain Projects and even then it seems to be different inside the project itself. The issue is not connected to SD/HD nor if the file was rendered or not.
No idea why this happens.Any thoughts?
Greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikangJeff Kirkland replied 11 years, 7 months ago 5 Members · 24 Replies -
Robin S. kurz
February 26, 2015 at 10:38 amLet me guess: footage is not optimized?
– RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich! -
Sascha Engel
February 26, 2015 at 10:56 amAll optimised – original footage comes from SONY A7s, FS700 & Canon C100.
Sascha Engel
http://www.youtube.com/taikang -
Jeremy Garchow
February 26, 2015 at 7:31 pmTurn off any unused (or empty) audio channels on your footage.
Jeremy Garchow
February 26, 2015 at 9:16 pmHey, Sascha. Send me an email if you can.
editstation at gmail
Jeff Kirkland
February 27, 2015 at 10:54 amI’ve had this happen from time to time too. In fact it’s just started up again in the last week or so.
The only thing I’ve found that seems to fix it, at least for a while is a clean install of my machine – which makes me think it’s an FCPX/OSX issue rather than anything to do with the media or libraries.
Are you using anything Blackmagic Design for monitoring? I’ve also wondered if it has something to do with the driver for my Blackmagic Ultrastudio Mini Monitor. Haven’t had a spare minute to investigate thougH.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland -
Eric Sternberger
February 27, 2015 at 11:08 amtry turning AV-display off, if you have a BM card and see what happens.
usually this helps on our 2013 mac pro with a decklink
on an older 2008 Mac Pro with an aja card the same timeline plays just fine
it´s the deck links driver – my2cents -
Sascha Engel
February 27, 2015 at 3:20 pmThat was my first thought as well, since I use BM. but even if I have AV output set to off, no monitoring, it still does it.
Besides if it’s the Driver, it wouldn’t make sense that with some clips on the TL I get a delay and with others not.Sascha Engel
Robin S. kurz
February 27, 2015 at 3:25 pmHave you tried hitting ctrl-⌘-1 and closing any open browsers and the inspector?
– RK
Sascha Engel
February 27, 2015 at 3:27 pmYes, also that.
No noticeable change when closed.Sascha Engel
Robin S. kurz
February 27, 2015 at 3:38 pmThen I personally would surmise that it’s not in fact an FCP issue and a fresh install of the OS is your best if not only bet, before you go on a week long witch-hunt, and nip matters in the bud. Little sense in running circles around the problem. 😉
– RK
