Activity Forums VEGAS Pro Deinterlacing prior to compression?
  • Deinterlacing prior to compression?
    Posted by Walter Mitty on July 2, 2005 at 2:06 pm
    I am trying to understand how I can deinterlace video prior to compression. Some codecs do not seem to have a deinterlace choice and I am wanting the video deinterlaced. 3ivx would be a good example. I like the job this codec does, and it looks good on TV, but I want to render some videos for playback on the computer. I think I am over my head here. Is there a filter or plug-in that I am not aware of, or is this just not possible with certain codecs. If this is the case, how can I get the best deinterlaced video compressed for PC viewing?
    Outside of a dog, a book is man’s best friend.
    Inside of a dog, it’s too dark to read.
    Laszlo Kovacs replied 21 years, 2 months ago 2 Members · 1 Reply
  • Laszlo Kovacs
    July 2, 2005 at 3:46 pm
    Check your project properties, if there’s a deinterlace method.
    And then when you’re going to render, click “custom” then on the
    “video” tab at “video format” choose your codec.
    2 lines above that you see “field order”, choose progressive.
    I guess this should work.
    Hope I could help.
    By(t)e
    Laca
