Deinterlacing AVCHD footage in FCP 7 or Compressor
I have a AVCHD Sony MC50U camera which can record in 1080 60i HD. I have been having many problems with this footage (converting to ProRes etc.) but I have managed to solve most of these issues, except for one, de-interlacing. The footage, instead of having lines, has a ghosting effect in which two frames are blended. This is extremely annoying especially when there is a fast pan. I looked all over the internet but have been unable to find a solution to this problem. In compressor i have tried to set the settings to a 1080 30p output with progressive selected but this did not help. I am actually quite inexperienced with compressor so any help would be appreciated. I have even tried the de-interlace filter on FCP 7 and this did not help. Oddly enough VLC’s “linear” de-interlace mode was actually able to eliminate the ghosting, albeit at a small loss of quality, but since VLC only plays back video I am unable to use this. Any help would be greatly appreciated, thanks.
