Activity Forums VEGAS Pro Deinterlace Method
  • Deinterlace Method
    Posted by Jacob Hobbs on September 26, 2007 at 12:08 am
    In Project Properties, there is Deinterlace Method option. Does this affect only video effects or also the rendered video?
    What should it be set for DV-AVI video? None?
    Jacob Hobbs replied 18 years, 11 months ago 2 Members · 4 Replies
  • Edward Troxel
    September 26, 2007 at 12:23 pm
    Standard DV is lower field first.
    For rendering, go to “Custom” and make sure it’s the way you want it set.
    Edward Troxel
    JETDV Scripts
  • Jacob Hobbs
    September 26, 2007 at 3:10 pm
    Yes I know standard DV is LFF. I have Vegas project set to Lower Field First.
    What does the Deinterlace Method affect? There are three choices, “None/Blend Fields/Interpolate Fields“. Since I am using standard DV and don’t want it deinterlaced, do I have to set this to “none” so Vegas won’t deinterlace my video? Or do these options only affect the Video Preview Screen?
  • Edward Troxel
    September 26, 2007 at 5:44 pm
    I don’t think it affects anything unless you change the field order to “None (Progressive)”
    Edward Troxel
    JETDV Scripts
  • Jacob Hobbs
    September 28, 2007 at 10:30 pm
    Thank you for confirming that! I played with it some more, and saw no difference.
