Activity Forums VEGAS Pro Deinterlace Method on already progressive video
  • Deinterlace Method on already progressive video
    Posted by Ilkka Aaltonen on March 13, 2011 at 5:42 pm
    I was wondering that what happens if I have already progressive footage and my Properties deinterlace method is set to Blend instead of None (as it is mostly when I open up the Sony Vegas) and I render the footage with this setting.
    In theory: does it make the final result look more blurry or will it be as clear as the raw footage without editing?
    John Rofrano replied 15 years, 5 months ago 3 Members · 2 Replies
  • Aleksey Tarasov
    March 14, 2011 at 9:10 am
    Vegas is smart enough and it won’t deinterlace progressive footages.
  • John Rofrano
    March 15, 2011 at 3:39 pm
    Yea, there is almost never a reason to set the deinterlace method to none. This should only be used if your project is interlaced and you are using some 3rd party plug-in for all of your deinterlacing but then you need to make sure that you manually apply the plug-in to every piece of interlaced footage yourself or else things will get ugly.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
