Activity Forums Maxon Cinema 4D Deforming a plane (or solid rectangle) that warps into a cylinder
  • Deforming a plane (or solid rectangle) that warps into a cylinder
    Posted by Colemanation on February 22, 2006 at 5:59 am
    Hi, everyone.
    I’m having a difficult time deformaing a plane which warps into a cylinder; maybe I’m going about it the wrong way :-/
    What I need to accomplish is this, using C4D XL Version 7.3:
    The animation begins with a “piece of paper” that fills the 4×3 video workspace. The “paper” then wraps into a cylinder (which will actually be a flag pole, necessitating a change in materials naturally) and settles in screen left, allowing space for a flag on the right side.
    It would preferrable to deform a thin solid rectangle so that you could see more dimension to the inside of the pole as it’s wrapping closed, but I’ll settle for a plane.
    The wrap deformer works fine warping the plane into the final shape of the cylinder, but I can’t seem to make it *animate* from flat to a totally revolved cylinder.
    Is there another way to go about this?
    Any help would be greatly appreciated.
    Thanks in advance.
    dc
    Colemanation replied 20 years, 6 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    February 22, 2006 at 5:55 pm
    It should work. What steps have you taken to animate the deformation?
  • Colemanation
    February 22, 2006 at 8:19 pm
    Hi, Adam.
    Actually, I think I have it figured out. I attempted to use the wrap deformer before; I switched to a bend deformer and I was able to do what I thought I could.
    Thanks for checking in, and sorry I didn’t provide many clues. I appreciate your help.
    dc
