Activity › Forums › Maxon Cinema 4D › deform on Collision
  • deform on Collision
    Posted by Ashley Goodall on April 7, 2010 at 9:50 am
    Hi all.
    I have a job were I need to have soap bubbles jiggle and deform as they float and collide. I have looked at the MOCCA Jiggle which works great. However I have know idea how to have the bubbles deform then jiggle as they collide. Anyone got any good ideas. I am medium level user of C4D, so I am not even shaw if this can be done?
    Thanks for any advice.
    Randy Johnson replied 16 years, 5 months ago 2 Members · 1 Reply
  • Randy Johnson
    April 7, 2010 at 2:14 pm
    Cloth is the way to go.
    Make all the bubbles one object and then you can play with the gravity, stiffness and even the particle effectors to get the movement you want.
    The jiggle deformer need to have key frames and would take a long time to set up.
    I guess mograph could get the collisions but not the impact movement like cloth.
    /Randy
