Activity Forums VEGAS Pro deflickering problem with virtuadub’s msu delicker
  • deflickering problem with virtuadub’s msu delicker
    Posted by Lars Hansen on October 18, 2011 at 10:52 pm
    I have a small problem with virtualdub’s msu deflicker plug-in that I’ve tried to resolve using the built in settings in multiple ways and seem to have have come to a dead end…
    Basically, the resulting rendered video, while deflickered nicely, is jerky. It plays evenly for a number of frames then pauses for a split second, then moves on pausing again after a similar time-frame, repeating this sequence all through the clip.
    I know that folks have had success with this program and plug-in (see: https://forums.creativecow.net/readpost/24/888486), but not sure why it’s not working for me?…
    Does anyone have experience with this software that may be able to help?
    Matt Crowley replied 14 years, 10 months ago 2 Members · 1 Reply
  • Matt Crowley
    November 18, 2011 at 9:06 pm
    What codec did you use when saving the video out of Virtualdub? If you used “Uncompressed”, then you will end up with a huge file which might not play smoothly simply because it can’t be read from disk quickly enough. Try one of the edit-friendly codecs like Cineform (if you have it), MJPEG, Lagarith, HuffYUV…
