Activity Forums Adobe Premiere Pro default transition not working
  • default transition not working
    Posted by Jeff Nelson on May 20, 2005 at 3:40 pm
    ?? It’s been working fine, then yesterday it stopped working, the Control-D option. When I look at the Sequence – Apply Video Transition — it’s not showing the option of applying any transition, it’s grayed out.
    ?? What the .. ?
    Jeff Nelson replied 21 years, 2 months ago 2 Members · 4 Replies
  • Steven L. gotz
    May 20, 2005 at 9:37 pm
    Are you selecting the correct track first?
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Jeff Nelson
    May 20, 2005 at 9:40 pm
    Not sure what you mean. I just put the edit line right between the two shots, on Video 1, and sometimes even hold down the shift key so that the little arrow shows I’m lined up right at the cut line, and then Control D, and nothing happens. It was working fine for a while there. Can’t figure it. THanks.
  • Steven L. gotz
    May 20, 2005 at 10:10 pm
    Is track one selected? Is the header section darker on track one than on the others?
    Steven
  • Jeff Nelson
    May 20, 2005 at 10:19 pm
    Thanks, Steven. When I clicked on that on the far left and made it dark, suddenly it works like a charm. Appreciate it.
