Activity Forums Adobe Premiere Pro Default Transition
  • Default Transition
    Posted by Sergio Lelevier on November 27, 2014 at 6:17 am
    i just downloaded PP. When I try to apply the default transition, I place the play head at the cut, click on comand D (Mac) and the dissolve goes to the end of the clip. What’s the fix?
    Tero Ahlfors replied 11 years, 9 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    December 6, 2014 at 10:30 pm
    If you have clip/clips selected it’ll put the transition on both ends. If you don’t have clip selected it should put the transition in the nearest cut on active tracks.
