Activity Forums Maxon Cinema 4D default setting
  • default setting
    Posted by Marc Daniel villarin on May 11, 2008 at 7:09 pm
    Can I set my cinema 4d preference settings back to it’s default?
    I got this new tutorial, unfortunately I messed up my settings. Especially in the color preferences/interface.
    I am using version 10 and I think the tutorial is 9.6. However my interface is in classic.
    Any help would be appreciated.
    Thank you.
    Look on the Bright Side…
    Shadab ßalőűsh replied 11 years, 4 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    May 11, 2008 at 9:57 pm
    Your settings should revert to default if you just delete your Cinema>Prefs folder. Be careful though — If you’ve set up custom shortcuts they will be deleted too.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Shadab ßalőűsh
    April 30, 2015 at 3:07 pm
    I cant move my object e.g CUbe by directly with the move line red,greenand blue what should i do to use it again ! ??? i,m new to cinema may be i changed some of the settings !
