Activity › Forums › Adobe Premiere Pro › Default metadata for new projects ?
Posted by Steven Smithsh on June 30, 2020 at 10:12 amHeres a picture split into two parts
Top pic, I underlined metadata columns with red,that is what always opens up by default with every new project
and bottom one underlined with blue is how I want it to be by defaultHow can I achieve this ?
Steven Smithsh replied 6 years, 2 months ago 2 Members · 5 Replies -
Andy Ford
June 30, 2020 at 2:17 pmRight-click on any of those column headings (name, frame rate, etc.) and select Metadata Display…
Then, check the boxes for the fields you want to see (under the Premiere Pro Project Metadata twirl-down menu) or add properties.————————————————-
Video Producer / Digital Marketer / Gear Reviewer / Author
— http://www.AndyFordVideo.com — -
Andy Ford
June 30, 2020 at 2:19 pmI should add, creation date is actually under the “Basic” twirl-down menu, whereas most of the other properties are under the Premiere Pro menu. Create your settings or schema as desired.
Steven Smithsh
June 30, 2020 at 5:11 pmThanks.
Now how can I make that a default metadata display everytime I open Premiere Pro new project ?
Andy Ford
June 30, 2020 at 6:24 pmAfter I set my metadata, I resave my workspace. This will open the project with my custom metadata fields in the future, so that’s good. But when I open a new project, it’s the default ones and I have to right-click to metadata display options and select my saved preset. That’s been a complaint for years on Premiere.
