Activity › Forums › Apple Final Cut Pro Legacy › default length of images dragged to the timeline
Posted by David Kuckhermann on May 10, 2011 at 7:46 amHello,
does anyone know if it is possible to set the default length (duration) for images that you drag into the timeline?
thanks,
David
Scott Maida replied 15 years, 4 months ago 5 Members · 4 Replies -
Rafael Amador
May 10, 2011 at 7:47 am -
Tom Wolsky
May 10, 2011 at 9:50 amWhat Rafael said. That changes the import duration. If you change it you would have to reimport the stills.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
David Eaks
May 10, 2011 at 10:02 amWhat they said. Also, if you have a few groups of stills that you want to have different durations, set the default, import the photos you want at that duration. Then change the duration and import stills at that duration, repeat as necessary.
Scott Maida
May 10, 2011 at 10:02 pmif you’ve imported stills and want a default duration, can that be accomplished without re-importing?
and is there a “Ken Burns’ preprogrammed move option,.. or am I just better served doing this glorified slide show in iMovie?
