Activity Forums Adobe After Effects default in px?
  • default in px?
    Posted by Hans Castrop on February 7, 2013 at 5:47 am
    I’m working with 3D layers, so also with Z depth. I’m keyframing the animation, but every time I want to put in the distance by right clicking on the Z depth it is back at px. It would be nice if it could stay on mm, because I’m working with real life sizes and measures. That way I could just put the distance in the timeline instead of going into the menu every time.
    I can’t find it in the settings. Am I overlooking something?
    Hans Castrop replied 13 years, 7 months ago 3 Members · 6 Replies
  • John Cuevas
    February 7, 2013 at 12:54 pm
    Exactly how are you getting MM to start? As far as I know AE works in pixels.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Hans Castrop
    February 7, 2013 at 1:17 pm
    I click on mouse right button on the figures for Z depth for instance. then I get “edit value…” and than I can choose between Units: Pixels, Inches, MM, %. Once I’ve choosen milimeter that works, but next time it’s back to px again.
  • John Cuevas
    February 7, 2013 at 1:46 pm
    You are correct, I did not know that functionality was there. I would suggest you bring this post and questions to the expressions forum and see if they have a way of using that MM data/or displaying it for you.
    Thinkck.com
  • Hans Castrop
    February 7, 2013 at 1:54 pm
    Oke, I considered changing the units type as basic, but I will post this question there also.
    thanks
  • Vishesh Arora
    February 7, 2013 at 3:06 pm
    I have checked on CS6 and CS3 version that If I change it to MM once, it will remain in that only for the next time.
    On which version you are working? Try installing the updates.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Hans Castrop
    February 7, 2013 at 6:40 pm
    I use CS6. once it has been changed to mm you can go back in this layers settings and it will still be mm, but what you see in the comp in the position keyframes they still are in px, so you still have to go into the actual keyframe setting bij rightclicking and Edit value…; it would be nice to be able to change the distance / position in the timeline.
