Activity › Forums › Adobe Premiere Pro › Default image lengths in PPro2
  • Default image lengths in PPro2
    Posted by Jason Bryce on July 10, 2008 at 6:31 am
    Hi, I’m just wondering about when I import an image into PPro (1 or 2), I can always set it quickly with the Length/Duration setting, or simply click and drag to the required duration on the timeline. However, when I import multiple images I can see no way to quickly select and then set ALL of them to a specified duration. Is this possible, and if so, how? Thanks!
    Harm Millaard replied 18 years, 2 months ago 2 Members · 3 Replies
  • Harm Millaard
    July 10, 2008 at 1:09 pm
    Look under preferences.
    Harm Millaard
  • Jason Bryce
    July 10, 2008 at 1:28 pm
    Okay, I found Still Image Default Duration (thanks) but that still doesn’t quite address my problem in full – what if I imported 30 clips, three batches of 10, and I wanted to set the first batch (all at once) to 20 frames in length, the second batch to 70 frames in length, etc – is there any way to do that? Or do I just change my default preferences, import the first lot, change my preferences again, import the second lot, and so on?
  • Harm Millaard
    July 10, 2008 at 2:03 pm
    That’s the way to go.
    Harm Millaard
