Activity Forums Apple Final Cut Pro Legacy Default Export Format. Plugin or way to change setting.
  • Default Export Format. Plugin or way to change setting.
    Posted by Josh Weiss on January 16, 2007 at 8:52 pm
    I use export using quicktime conversion very frequently and have a format that I use 95% of the time. However, every time I close final cut I have to redo the settings. Does anyone know how to change the default or a plugin that allows you to do this?
    Isaac Kumer replied 15 years, 3 months ago 4 Members · 5 Replies
  • Steve Eisen
    January 16, 2007 at 9:11 pm
    Compressor! Create as many custom settings as you want plus a long list of pre-set settings.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Josh Weiss
    January 16, 2007 at 9:23 pm
    Yes, I occasionally use compressor, but its ridiculous that you can’t change the final cut default. Its quicker and easier not to have to go through compressor.
  • Bob Flood
    January 16, 2007 at 9:52 pm
    JW
    Yes it is too bad
    HOWEVER
    What i have found to work best and fastest is to export out of FCP a self contained movie using default, which matches whatever your sequence is set to, and then use compressor to convert. why? cuz i can run compressor in the background while still editing, instead of waiting for compressor to finish.
    i beleive , although i have not tried it yet, there is way to make a “droplet” that makes using compressor even faster.
    hope this helps
    bee eph
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Josh Weiss
    January 16, 2007 at 10:04 pm
    Well I wish there was a better way. However, i did look up the droplet and that is a very nice feature.
  • Isaac Kumer
    June 21, 2011 at 8:21 pm
    agreed. i must export 150 still frames (not in sequential order) as png’s i set up markers for all the stills i need and hot keys 1,2,3 to got to next marker, copy the time code, exp-conv, save tc number as file name, and then manually pull the menu for still image. streamlined this grunt work for everything but the pull down menu. i have 300 more to do, total grunt work, did i mention that. and no, mac automator is not doing the job its supposed to – even after i delete the plist. i feel plist off. any one else have any input to save my day would be greatly appreciated.
