Activity › Forums › Apple Final Cut Pro › Default description/creator/tags for Shares?
  • Default description/creator/tags for Shares?
    Posted by Jaeson Koszarsky on January 25, 2024 at 7:54 am
    I’m using FCPX 10.4.6 on a 2010 12-core Mac Pro with 10.13.6.
    Every time I share a file, the information under the info tab for description/creator/tags resets. Is there a way to change this? Rather that my username for creator, I often want to put in my company name. Or I may want to use the same set of custom tags.
    Jaeson Koszarsky replied 2 years, 8 months ago 3 Members · 3 Replies
  • Robert Olding
    January 25, 2024 at 3:54 pm
    It’s done on the Project level. Select a Project in the Browser and then in the Inspector window you’ll see the three-arrow icon. It’s called the “Share Inspector”. You can fill out the fields there and FCP will remember your custom settings for that particular Project.
  • Jeremy Garchow
    January 25, 2024 at 6:44 pm
    You can also save your setting as default. At the top of that list, you can use the little drop down menu as “Save as Default”.
  • Jaeson Koszarsky
    January 26, 2024 at 5:49 am
    Thank you! This is just what I was looking for.
