Decompose and re-digitize from tape problem
After a decompose of a sequence, some of the resulting subclips are offline. Other subclips from the same master clip are still online. Why might this be the case? I appear to be stumped.
Edit: I believe this is due to a DVCAM 40 tape that has timecode that runs to 60 minutes. The TC on the tape is written thusly: 00:00.00:00 with a period between the minutes and seconds. Is it possible this is confusing the Avid and/or deck and causing these problems?
