Activity Forums Apple Final Cut Pro Decoding XML Import Warnings
  • Decoding XML Import Warnings
    Posted by Ellen Bittner on July 11, 2017 at 7:19 pm
    Hi Guys,
    I got the following warning when importing an XML. Everything appears fine in the project, but I’m worried there’s something I didn’t get that I don’t know about. This is the warning:
    Your XML was imported with the following warnings:
    The effect ID is invalid. (ref=”r10″: /fcpxml[1]/library[1]/ event[1 ]/project[1 ]/sequ ence[1 ]/spine[1 ]/asset-cli p[1 ]/filter­video [1 ]/@ref)
    Anyone know what this XML import warning might be related to or how to read this warning in general so that I can find the culprit? Thanks!
    – Ellen
    Ellen Bittner replied 9 years, 2 months ago 2 Members · 4 Replies
  • Jeff Kirkland
    July 11, 2017 at 9:11 pm
    What was the XML created in? I’d guess you’re missing an effect but these messages are so cryptic it can’t be more than a guess.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Ellen Bittner
    July 11, 2017 at 9:21 pm
    Thanks, Jeff.
    The XML was created in FCPX, with Metadata View set to “General” and XML Version set to “Current Version (1.6)”
    I didn’t bring the XML through any other software, just straight from one apple computer to the other, both with the same version of FCPX running. I appreciate your guess at what’s going on here!
    – Ellen
    Thank you,
    Ellen
  • Jeff Kirkland
    July 11, 2017 at 9:54 pm
    You might try running the XML through X-FX Handler. It can show you any effects, title or generators that are in the XML but unavailable on your computer.
    https://www.spherico.com/filmtools/X-Files/X-FXHandler/
  • Ellen Bittner
    July 11, 2017 at 10:16 pm
    Thanks, Jeff! That was just what I needed to de-code my FCPXML. I love this community!
    Thank you,
    Ellen
