Activity Forums Blackmagic Design Decklink to Y/C (S-Vid)? Any low cost converters?
  • Decklink to Y/C (S-Vid)? Any low cost converters?
    Posted by Jon Watkins on November 10, 2005 at 4:54 pm
    Can anyone point me to a solution to get a Y/C (S-Vid) connection out of my DecklinkSP? I have seen the Aja D4e but was hoping somebody knew of something cheaper.
    Jeff Bernstein replied 20 years, 10 months ago 7 Members · 9 Replies
  • 9 Replies
  • Neil Sadwelkar
    November 10, 2005 at 5:47 pm
    I’m not entirely sure of this and someone who knows can say for certain, but …
    If one were to ‘combine’ the R-Y and B-Y outs into one and take the Y as one and then ‘shoe-horn’ these into a S-video jack. Y as Y and R-Y and B-y combined into one as C you should have Y/C.
    Right? Again, I’m not sure. In fact I’m not even sure if tryong this out would damage your SP card.
    Neil
  • Jeff Bernstein
    November 10, 2005 at 6:38 pm
    And where would the green come from? You can’t do it this way.
    Jeff Bernstein
    Digital Desktop Consulting
    Apple Pro Video VAR
    XSAN Certified
    323-653-7611
  • Mike Johnton
    November 10, 2005 at 8:34 pm
    We use these, and they work great!
    https://www.svideo.com/svideorca.html
  • Jeremy Garchow
    November 10, 2005 at 8:54 pm
  • Jon Watkins
    November 10, 2005 at 10:16 pm
    Thanks for the input guys- but a few questions for Mike and Jeremy. Mike- which converters specifically do you refer to on your weblink? All I really see are S to RCA adapters. And Jeremy, how exactly does this cable interface with the decklink? The Y (of Y/C) I assume will come from the Decklink Y, but what about the chroma? How do I get the Y-B and Y-R signals combined?
    For a little more clarification- again what I am trying to accomplish is Component Y, Y-R, Y-B OUTPUT from the decklink to S-Vid (Y/C) INPUT on my 9″ pro monitor (much higher quality than using the Y cable in composite mode -which I am currently using)
    Jon
  • Jeremy Garchow
    November 10, 2005 at 10:48 pm
    Nevermind, decklink doesn’t support S-Video out.
    You’ll need some sort of box or deck.
  • Steve Wargo
    November 11, 2005 at 7:42 am
    You need to change monitors, dude.
    sw
  • Viveck
    November 11, 2005 at 11:41 am
    [Jeff Bernstein] “And where would the green come from? “
    FYI – It is possible to have green if you have red and blue available, how do you think Y, Y-“R” and Y-“B” work?
    and Neil you do have some interesting theory but it’s not gonna happen like that. Think of S-video more like native television format. Basically instead of routing CVBS on a single carrier, what you have is Luminance (VBS) and Croma (C – colour information) seperately. This way croma doesn’t have to piggy back Y (luma), which also means that Y gets full bandwidth. and we get better sharper video and better colours.
    Digital motion, don’t even bother to convert composite to Y/C, you will still be looking at composite quality. Best would be to have component monitor.
    Cheers
    vB
  • Jeff Bernstein
    November 11, 2005 at 5:30 pm
    If you follow the thread, the poster referenced a bunch of simple cables with no active electronics. Of course you can get Green from YUV, but not without some active electronics.
    Jeff Bernstein
    Apple Pro Video VAR
    XSAN Certified
    323-653-7611
