Activity Forums Blackmagic Design Decklink Studio peak audio problem
  • Decklink Studio peak audio problem
    Posted by John Greenstine on May 25, 2011 at 12:44 pm
    When playing a Premiere CS5 Blackmagic sequence in my new system with Decklink Studio, the audio output of the Blackmagic card has loud crackles and pops at audio peaks, even those fairly low in amplitude. AES/EBU outputs do not show this problem. Files are not distorted in any way. Do not have this problem when playing a conventional Premiere sequence through the PC sound card into same amp and speakers, no matter how loud the peaks. Decklink card has latest (8.0.1) drivers and firmware.
    John Greenstine
    Sr. Video Producer
    Unisys Corporation
    Paolo Castellano replied 15 years, 4 months ago 2 Members · 3 Replies
  • Paolo Castellano
    May 26, 2011 at 6:19 pm
    Hello,
    if you are using unbalanced speakers, your problem could be due to the need of stereo jack connectors for “mono” audio channels.
    There was a link on the BlackMagic website, that was probably removed (I can’t find it now).
    Best Regards,
    Paolo
    https://www.ivsEdits.com
    Paolo.Castellano@ivs.it
    “Post Fata Resurgo”
  • John Greenstine
    May 26, 2011 at 6:43 pm
    Paolo, you are exactly correct. Switching to stereo cables eliminated this problem. Thank you!
    JG
    John Greenstine
    Sr. Video Producer
    Unisys Corporation
  • Paolo Castellano
    May 26, 2011 at 7:29 pm
    You are welcome!
    Paolo
    “Post Fata Resurgo”
