Activity Forums Blackmagic Design Decklink SP/Pro clashing with ATI RadeonX600 PCI-e Card
  • Decklink SP/Pro clashing with ATI RadeonX600 PCI-e Card
    Posted by Dennis Pereira on April 14, 2005 at 3:26 pm
    Hi we have a SuperMicro system X6DAL-G with Dual Xeon 2.8GHz CPU, 4GB RAM, 80 GB IDE HDD, Windows XP SP1 & sP2. This is a PCI-e (16x) slot into which is installed an ATI Radeon X600 Display card. Whenever I try installing the Decklink SP or Pro card into this machine, it crashes when the Decklink display is being installed. After that the systems is unable to boot up. Only boots up in VGA mode.
    If i uninstall the X600, ie bootup with standard vga (microsoft), I can install the blackmagic card. But as soon as ATI drivers are installed, it crashes.
    Problem is that I am going to be running some software on it which requires X600 card.
    So is there anyway to get decklink to work with an x600?
    thanx
    Dennis
    Sean Oneil replied 21 years, 5 months ago 2 Members · 1 Reply
  • Sean Oneil
    April 15, 2005 at 12:43 am
    Try diabling the Decklink as a 2nd (or 3rd) monitor.
