Activity Forums Blackmagic Design Decklink SP pcie output to VCR
  • Decklink SP pcie output to VCR
    Posted by Elijah on September 1, 2006 at 9:31 am
    Hi all,
    Was just wondering if this can happen & the connections required.
    thank for all the replies
    cheers
    aha
    Kristian Lam replied 20 years ago 2 Members · 1 Reply
  • Kristian Lam
    September 6, 2006 at 5:57 am
    Sure. Chances are your VCR is using a composite connection on its input. Just use the Y output cable from the DeckLink card and rememeber to switch the card’s output settings to composite.
    You’ll need converters for your audio to bring it to the right levels. The DeckLink SP’s output will be too hot for a consumer VCR. Try something like this:
    https://www.rolls.com/new/mb15.html
    regards
    Kristian Lam
    Blackmagic Design
