Activity › Forums › Blackmagic Design › DeckLink SP and Matrox Pharelia
Posted by Ernesto/proservice on April 4, 2005 at 7:33 pmDear Forum,
I’m try to configure DEcklink sp on Intel SE-7525gp2 and 3 monitor using Pharelia’a AGP card
is teh Pharelia’s aproved Hardware for use with Decklink and this mother ?
if it is not please let me konw wich Agp car can I use for 3 monitor.
I wait.
Regards.Igor Litviak replied 21 years, 5 months ago 3 Members · 7 Replies -
Dalen Quaice
April 4, 2005 at 8:17 pmNo the Matrox card is not supported.
I’d suggest you try an Nvidia based card such as the Quadro4 for multi-montiors.
Ernesto/proservice
April 4, 2005 at 9:06 pmBUT, This Nvidia Card only support 2 VGA monitor . do you know wich model in particular ?
Thanks for your answer.
Regards. -
Dalen Quaice
April 4, 2005 at 9:37 pmYou can add an extra PCI based nvidia card to support a 3rd monitor.
Dalen Quaice
April 4, 2005 at 9:48 pmBTW, the board you mentioned – the SE-7525gp2 doesn’t support AGP cards. It only takes PCI Express 16x and x4.
Dalen Quaice
April 4, 2005 at 11:29 pmThe Supermicro X5DAE is a great AGP dual Xeon board (2.8Ghz or higher) that supports Decklink SP.
You can also use Decklink SP with a lower cost Supermicro P4SCT+II Pentium 4 3.0 GHz or higher.
Most nvidia based graphics cards will work fine with no issues. Not all boards will support multi-monitor configs.
Igor Litviak
April 12, 2005 at 9:09 pmHi Ernesto!
Matrox Parhelia is working fine with DeckLink SP. I have two workstation based on different motherboard (one – dual xeon, another – single P4 3.2).
Use latest matrox driver and latest Blackmagic driver – and enjoy!As a sample – configuration of my very stable workstation:
MB – ASUS PC-DL Deluxe
CPU – Dual Xeon 3.0
Video – Matrox Parhelia with dual LCD monitor and one composite – connected TV monitor
Boot HDD – Samsung 7200 RPM
Temp/Swap/Scratch HDD – Samsung 7200 RPM
Video array – Stripe set of 4 x 250 GB SATA HDD with Promise FastTrak S150 SX4 RAID controller
Beta tester’s device 🙂 – Blackmagic DeckLink SPWindows XP SP2
Adobe Premiere Pro 1.5.1We make on it TV serial be made of over 120 hour Beta SP source.
Good luck! (Luke is handsome)
