Activity › Forums › Blackmagic Design › DeckLink SDI question
  • DeckLink SDI question
    Posted by Anmol Mishra on March 12, 2010 at 10:22 am
    Hi! I was looking for an option to record 10-bit 4:2:2 hd-sdi from a PMW-EX1. Is the DeckLink SDI the cheapest option to actually ingest 4:2:2 1080i HD-SDI with Cineform NeoHD ?
    I am concerned about it actually being 10-bit internally, as the Intensity card advertised 10-bit internally but were only 8-bit..
    Another concern is whether it actually allows HD recording. Some of the earlier HD-SDI cards were NTSC/PAL SD resolution only..
    Mario Torres replied 16 years, 5 months ago 3 Members · 2 Replies
  • Callum Mclay
    March 14, 2010 at 10:59 pm
    Hi Anmol
    The Decklink SDI, as well as all the current Decklink range, is a full 10 or 8 bit, HD/SD capture card, and you can check out the tech specs for the Decklink SDI card here:
    https://www.blackmagic-design.com/products/decklink/techspecs/
    Our previous range of Decklink cards did include SD-SDI only capture cards, but our current range of Decklink cards are all brand new as of 2009, and can do HD or SD capture on the same connections.
    Callum McLay
    Technical Support Manager
    Blackmagic Design EMEA
  • Mario Torres
    May 5, 2010 at 3:22 pm
    Saludos soy mario torres de republica dominicana, trabajo en un canal de televisión, hemos adquirido una tarjeta blackmagic decklink estudio para integrarla a nuestro sistema y atra ves de ella reproducir un archivo en formato AVI.
    utilizando los software reproductores que la tarjeta trae no hemos podido obtener video y audio en su salida.
    Por lo que procedimos a instalar el programa de adove premiere, en donde solo pudimos obtener señal de audio por la salida sdi de la tarjeta.
    Alguna sugerencia??
    gracias.
