Activity Forums Blackmagic Design Decklink SDI for SD streaming – can I superimpose a graphic?
  • Decklink SDI for SD streaming – can I superimpose a graphic?
    Posted by Cian O’carroll on February 6, 2012 at 5:17 pm
    I am using a Declink SDI card to stream SD live events, and to stream replays after the event has finished.
    I would like to add an on-screen graphic to say “Live” or “Recorded Earlier”.
    Will I be able to do this on a single card – In other words, does the card put the overlay the graphic before the video gets to the streaming encoder or after?
    C.
    Cian O’carroll replied 14 years, 6 months ago 1 Member · 1 Reply
  • Cian O’carroll
    February 13, 2012 at 4:19 pm
    I have found that the answer is no! When you use the board as a streaming card, the LiveKey software tells you that the card is in use by another process.
    I had a second decklink SDI card handy, so I now have one as the Keyer and one as the streaming card.
    C.
