Activity Forums Blackmagic Design Decklink Pro (PCIe) Pref Settings for SDI Monitoring – no sync ???
  • Decklink Pro (PCIe) Pref Settings for SDI Monitoring – no sync ???
    Posted by Jennifer White on March 19, 2008 at 7:53 pm
    What are the decklink pref settings for connecting to Broadcast monitor via SDI port. I put “Set output : SDI & NTSC/PAL (Y Out)” and “Set input to NTSC/PAL (Y In), but I get “no sync” on SDI, however if I connect COMP/RGB the image is fine. If I “set output; SDI & NTSC/PAL (Y Out)”, I get image very pixelated (like lo-res).
    I also have “Set black ref on video output in capture” unchecked
    When not playing, send: Last played Frame
    Set reference input not detected “0”
    Jen
    Jennifer White replied 18 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
