Activity Forums Blackmagic Design Decklink Pro Pal component levels too low?!?
  • Decklink Pro Pal component levels too low?!?
    Posted by Jan Schulz on October 23, 2006 at 8:05 pm
    my Decklink Pro ouptuts too low analog levels. 100 % White in FCP generate about 85% on the component WFM. SDI Levels are fine. If I output the same white to DigiBeta and then measure it through the component out of the DVW-M2000P I get the correct reading.
    Drivers are 5.7.2
    FCP is 5.1.2
    So whats the deal? And more importantly: What can I do to get rid of this annoyance??
    Jan
    Igor Babic replied 19 years, 11 months ago 2 Members · 3 Replies
  • Igor Babic
    October 25, 2006 at 1:51 pm
    Try to test your analog component cables from DL Pro first. Try also analog composite out. I am also chaising some weird things like you and find out that my patch cables has sometimes problems and this is nothing to do with DL cables.
  • Jan Schulz
    October 25, 2006 at 9:22 pm
    I get the same weird luma levels when going composite out.
    And there are no patch cables as i go directly from the breakout cable to the wfm.
    This is really strange and i couldn’t find anything on the net regarding this.
    Maybe the card itself is bad…
    Let me know if you find something out.
  • Igor Babic
    October 26, 2006 at 7:06 am
    Ups… My problem is smaler then yours. I have checked, and is cables. Try to contact Luke at BMD. Good luck.
