Activity Forums Blackmagic Design Decklink Mini Monitor and Asus MX239H
  • Decklink Mini Monitor and Asus MX239H
    Posted by Thomas Woodroffe on June 20, 2015 at 2:35 am
    Hello,
    I just bought an Asus IPS monitor (MX239H) and a Decklink Mini Monitor PCIe Card. I’m trying to make them work with DaVinci Lite, but I’m having some problems: the problem is that when I try to set up the output from DaVinci to 1920×1080 progressive at any frame rate (23,976, 24, 25, 29,978 and 30 are the possibilities) the screen stays black with a “OUT OF RANGE” message. But if I change the output to 720p at 60 fps or 50 fps, it works perfectly.
    So, I thought maybe the monitor only works at 50 and 60 hz. And I tried setting the output to 1080i at 60hz (30fps) or 1080i at 50hz (25fps). But it didn’t worked either… just like the first time: “OUT OF RANGE” message.
    The monitor works perfectly at 1080p at 50 and 60 hz if conected to my nVidia GTX 750.
    Can anyone help me to make it work at 1080p23,976? Is posible to output from the card at a “converted” frame rate, different from the one selected in the project?
    Thomas Woodroffe replied 11 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
