Activity › Forums › Blackmagic Design › Decklink HD Pro 4:2:2 Questions
  • Decklink HD Pro 4:2:2 Questions
    Posted by Martin Phillips on February 13, 2006 at 9:33 pm
    I am looking to install this card into my G5 2Ghz. Will it let me input / output via SDI DigiBeta & HDCAM whilst simultaneously monitoring via Component on a CRT monitor?
    Also, does it come with the breakout cable or is that bought seperately?
    Thanks, Martin.
    Kristian Lam replied 20 years, 7 months ago 2 Members · 1 Reply
  • Kristian Lam
    February 17, 2006 at 3:29 am
    Yes, you can monitor off the component outputs of the card when capturing or playing back. The breakout cable is included.
    However, do make sure that you’re Power Mac G5 is a PCI-X machine. PCI only G5s are not supported.
