Activity Forums Adobe Premiere Pro Decklink HD for offline solution?
  • Decklink HD for offline solution?
    Posted by Joel Cheek on June 9, 2006 at 10:45 pm
    Hi. I’m new to Premiere Pro 2.0. I’m half-way through editing a long documentary and we’ve run into major problems due to digitizing offline footage with older Matrox cards. The timecode got messed up when we upgraded to 2.0, but we didn’t realize it at first. Now we’ve done a lot of editing with bad timecode. I’m trying to figure out if we can port the project over to Decklink cards somehow. We have one Decklink HD card right now and may purchase more. But we don’t have the budget for huge RAIDs, so we want to use the Decklink cards with offline DV footage and then online with uncompressed HD via one of the cards. Can we just use DV footage as offline sources with Decklink cards and then redigitize the same footage into uncompressed HD from the Premiere project (as opposed to an EDL). If so, can we edit the same project with offline DV footage on other stations without Decklink cards? The footage was shot with a Panasonic Varicam and digitized to a DV codec (Matrox version). Is there anyone using this kind of workflow?
    Any help is greatly appreciated? Thanks!
    Joel Cheek replied 20 years, 3 months ago 2 Members · 2 Replies
  • Ken Adolph
    June 10, 2006 at 4:47 am
    I don’t know how you can correct the problem of lost TC because of the change to 2.0. However, we work with this offline process all the time. We just dub the HD or SD footage to DVcam with matching TC and capture from there with firewire, etc. You don’t need a capture card to do this.
    If you pass the Ppro project from edit station to edit station then the TC remains intact. You can then re-digi at full resolution for the on-line.
    We have done this for documentaries, feature films and commercials. We can even import projects edited this way from FCP and Avid.
    Ken Adolph
    Media Group
    Editor/Post Supervisor
    https://www.mg.ca
  • Joel Cheek
    June 10, 2006 at 5:47 pm
    Ken, thanks so much for your response. That’s really helpful. My co-worker started another thread today about the timecode problem in PPro 2.0. I assume you haven’t had any TC problems with 2.0, right? We’re trying to find a way to salvage this huge documentary.
    Thanks again.
