Activity Forums Blackmagic Design Decklink HD extreme (version1) and o/p in prmiere
  • Decklink HD extreme (version1) and o/p in prmiere
    Posted by Ivan Zbiral on August 24, 2011 at 9:42 pm
    Hello !
    is it possible to have output from SDI out of this card to an external monitor. I have been using this card for 3 years in final cut without a glitch and I would like to do the same thing in Premiere CS 5.5. I cant figure out how to have output at all. Do I have to enable it in premiere somewhere? Any advice is highly appreciated.
    ivan zbiral
    cyberucho@volny.cz
    Chris Tompkins replied 15 years ago 3 Members · 2 Replies
  • Chris Pearse
    August 25, 2011 at 8:30 am
    Hi Ivan,
    To output from your Premiere Pro timeline via your Blackmagic card you will want to use one of the Blackmagic Design sequence settings. Amongst the sequence presets in the New Sequence window should be a folder for these. if you don’t see them it may be that the driver for the Blackmagic card was installed prior to installing Premiere Pro. If you re-install the latest driver I think these should then appear.
    Chris Pearse
    Technical Support Consultant
    Blackmagic Design EMEA
  • Chris Tompkins
    August 25, 2011 at 3:43 pm
    You have to re-install the BMD drivers AFTER you install CS5.x for them to show up. – FYI
    Chris Tompkins
    Video Atlanta LLC
