Activity › Forums › Blackmagic Design › Decklink HD Extreme 3D card to BetaSP
  • Decklink HD Extreme 3D card to BetaSP
    Posted by Rex Summerfield on March 15, 2011 at 7:05 am
    I have a new card on a new system and could use a little help. The breakout cable has a connection for Black Sync “IN” so I assume the card needs a Black Sync signal input to it. Do I need to run the black sync to the card AND the SP deck or just to the card? Nothing in the documentation about this so I could use some guidance.
    Kristian Lam replied 15 years, 6 months ago 4 Members · 4 Replies
  • Shane Ross
    March 15, 2011 at 8:08 pm
    Both. VERY important that the Deck have this too.
    Shane
  • Rex Summerfield
    March 15, 2011 at 8:21 pm
    Thanks!!
  • Eric Cox
    March 18, 2011 at 5:08 pm
    sync goes everywhere!
    I cannot recall if the blackmagic device will automatically use the sync input. Make sure you check the application to ensure that if a sync option is available that it is enabled.
    The same can be said for the deck as I have seen some which did not automatically enable the input or perhaps some nefarious individual disabled the option.
  • Kristian Lam
    March 21, 2011 at 2:10 am
    [Eric Cox] “I cannot recall if the blackmagic device will automatically use the sync input”
    Yes, our products have automatic sync detection so if one’s connected, it will be used.
    regards
    Kristian Lam
    Blackmagic Design
