Activity › Forums › Blackmagic Design › Decklink Extreme & Premiere (No Capture)
Posted by Bobby Poole on October 27, 2005 at 9:31 pmI’m
Luke Maslen replied 20 years, 10 months ago 4 Members · 6 Replies -
Deleted User
October 27, 2005 at 11:19 pmHello,
Okay in Adobe premeire Pro, if you are capturingvia Firewire you have to enable in Device control (DV device) 1394.
This should solve the problem.
Warm Regards,
LEO BAKER
SYNC FILMS
Web: http://www.syncfilms.com
E-Mail: leo@syncfilms.com -
Bobby Poole
October 27, 2005 at 11:26 pmI’m not capturing via firewire. I have the decklink card to capture with, but hasn’t worked yet.
Luke Maslen
October 28, 2005 at 4:18 amHi,
After installing the DeckLink Extreme in to a Mac or PC, you might find that you cannot capture video. The reason for this is that you first need to specify which video input you are using, ie SDI, component analog or composite analog.
In Mac OS X, open the System Preferences and then click on Blackmagic DeckLink.
In Windows XP, go to the Start menu, click on Settings, open Control Panels and then the DeckLink control panel.Look at the settings for Video Connections and set the Input as desired, ie:
* Digital SDI
* Analog NTSC/PAL (Y In) – also known as composite analog.
* Analog Y, B-Y, R-Y – also known as component analog.Video output is always sent to both SDI and analog outputs simultaneously so the only choice you might want to make here is between component and composite output.
Now that you have made these changes, you should be able to capture video with DeckLink Extreme.
Regards,
Luke Maslen
Blackmagic Design -
Bobby Poole
October 28, 2005 at 8:18 pmI’ve tried both component and composite. Neither works on the XP system. It works flawlessly on Mac with FCP.
Sameer Shrivastava
October 28, 2005 at 11:00 pmHi,
I am not sure, but please check capture settings, playback video and audio on desktop should be checked on for both preview and capture.
Or try changing ver. of the driverssameer shrivastava
Luke Maslen
October 31, 2005 at 1:47 pmHi,
What is the source of your video, eg Digibeta, Betacam SP or something else?
Regards,
Luke Maslen
Blackmagic Design
