Decklink Extreme PCI and G5 help please?
Hi all,
I’m actually an audio guy, but am looking at setting up a basic Final Cut system at my studio for editing SD material. (Final Cut 6 on OS 10.4) I’ve been running a Decklink Extreme PCI card (not PCIe) with Adobe Premeire, but want to move it into an older G5 (still to buy). I’ve found these statements on Black Magic’s website, and am curious if anyone has been able to stably run a Black Magic regular PCI card on a G5?
“PowerMac G5’s with 33 MHz PCI slots should not be used with DeckLink cards. Please review the latest compatibility information regarding G5’s with 33 MHz PCI slots.”
If interested–this is the full link explaining which G5’s do NOT work:
https://www.blackmagic-design.com/support/detail.asp?techID=76
“In summary, none of the PowerMac G5’s, with 33 MHz PCI slots, should be used with DeckLink cards at this time. Hopefully this advisory will change in the future if Apple are able to resolve the issues with the PCI slots.”
From their info, I’m understanding that Decklink PCI cards aren’t compatible with G5’s. Only the PCIe versions work? I’m assuming I should just buy a PCIe card instead of trying to find a G5 that will work around my existing card. Has anyone gotten a Decklink Extreme or similar BM PCI card to work on a G5 without the problems blackmagic lists?
Thanks a ton!
Matt
