Activity Forums Blackmagic Design Decklink Extreme operation question
  • Decklink Extreme operation question
    Posted by Joseph Owens on January 6, 2012 at 12:46 am
    I’m coming over from AJA to Blackmagic Design, so I’m at a bit of a loss as to how to configure their cross-conversion and down conversion. I’m used to being able to assign the SDI outputs directly to a particular resolution and frame rate in the AJA control panel, but of course BM does not have such a thing… so is it even possible to set the SDI A, B and analog outputs to a specific format? Not obvious in the Preferences dialog and also not covered in much detail in the manual…
    jPo
    You mean “Old Ben”? Ben Kenobi?
    Joseph Owens replied 14 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
