Activity Forums Blackmagic Design Decklink Extreme on XP, downconversion HD – SD, future proof question
  • Decklink Extreme on XP, downconversion HD – SD, future proof question
    Posted by Igor Babic on September 15, 2005 at 8:20 am
    Is it posible to do this now in Premiere in real time and can I edit HD with this card, or is it in your plans in next driver realeses?
    Adam Portnoy replied 20 years, 11 months ago 3 Members · 2 Replies
  • Luke Maslen
    September 16, 2005 at 6:22 am
    Hi Igor,
    We can do HD 1080 down conversion with the DeckLink HD Pro 4:4:4 hardware on Windows XP. The other cards do not currently perform down conversion on Windows. This contrasts with Mac OS X where we are able to offer software down conversion on all DeckLink cards.
    The DeckLink HD Pro 4:4:4 can perform down conversion in Premiere Pro right now. The cost of the DeckLink HD Pro 4:4:4 has just dropped to US$1495 following an announcement at IBC 2005. It works in SD and HD as well as both 4:2:2 and 4:4:4.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Adam Portnoy
    September 16, 2005 at 8:08 pm
    Does downconversion work in After Effects on the PC or is that a different process? If I have an HD project in After Effects with a Decklink SD card what will I get on my non-HD NTSC monitor?
    Also, does audio from an After Effects project go out in video preview to the Decklink card? I’m currently using a DV converter and there is a huge delay between the internal audio and external video preview on the NTSC monitor.
    Adam
