Activity Forums Blackmagic Design DeckLink Extreme HD – flicker on HD output – Mac OS X
  • DeckLink Extreme HD – flicker on HD output – Mac OS X
    Posted by James Fuller on October 6, 2008 at 1:51 pm
    I’ve been using a DeckLink Extreme HD in FCP Studio 2 for SD projects for over a year now. No problems other than a few crashes when using 10bit – nothing to worry about. Until now…
    We’ve just invested in a Sony LMD-2050W boradcast LCD monitor, with a BKM-243HS SDI input adapter as part of a move toward HD production.
    However, when outputting almost any type of HD from the DeckLink, I get a intermittent flickering signal. This intermittent signal carries through to the audio and is apparent all the time, (on stills, not just on moving images and not just when playing clips/the timeline). It is apparent regardless of the connection (SDI or component).
    The card continues to output without problems in PAL and NTSC, and seems fine if I use 8bit codecs in FCP. However, this severely limits the codecs we can use (eliminating the use of ProRes, for example). Using ‘Extended Desktop’ is impossible in either 1080 or 720, while After Effects does not give the option of displaying 8bit, so it becomes unusable for HD work…
    To begin with I thought this was a fault with the monitor, but I’ve connected it to our AJA ioHD (which only outputs 10bit) and there are no problems. The fact that the problem occurs in the audio too suggests a problem with the card.
    I’ve tried contacting Blackmagic’s support, but have had no reply. I can’t find anything on the internet regarding this issue.
    Does anyone have any tips? Does it sound like a fault with the card, or am I missing something?
    System: Apple Mac Pro Dual Quad Core 3GHz, 13GB RAM, 250GB HD (System and Apps), 2.25TB (3x750GB) RAID (for media/projects). OSX 10.5.4, Final Cut Studio 2, After Effects CS3, Photoshop CS3, Illustrator CS3.
    Ryan Jenkins replied 17 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
  • Chris Blair
    October 6, 2008 at 5:06 pm
    Define intermittent.
    We use an Sony LMD series (LCD) monitor with the Decklink HD Extreme with Premiere and Vegas and progressive video just plain looks weird on these. 60i video looks fine, but any of our 24P and 30P footage shot with a Panasonic SDX-900 has an odd “stutter” even after rendering. The same footage and rendered movies look and play fine on Sony broadcast NTSC monitors when played back through the Decklink, so we’ve determined it’s something in the LMD monitor, which in my opinion are NOT very good monitors.
    This happens on SD material as well as HD…so that doesn’t seem to have any affect.
    We bought 2 of the LMD’s and we’re really disappointed with the quality (or lack thereof) considering their price. Perhaps it has something to do with the inherent nature of how an LCD monitor dislpays progressive footage, but compared to our old Sony broadcast monitors, it’s just plain odd looking.
    Chris Blair
    Magnetic Image, Inc.
    Evansville, IN
    http://www.videomi.com
  • James Fuller
    October 7, 2008 at 9:32 am
    ‘Define intermittent’ – headache inducing. By intermittent, I mean that the image on display literally flashes on and off. The speed of flashes depends on the screen resolution/refresh rate – 720p50 flashes very fast, 1080i25 slightly less, etc.
    I’d love to be able to comment on the quality of the monitor, but the image onsceen is never stable enough to see the image – except when outputting in 8bit, which is often not an option.
    Here’s another aspect of the problem: if I play a clip, FCP reports dropped frames. It’s like the timing of the whole system goes crazy when the display is set to output HD at 10bit (which is surely what it is supposed to do, right?)
    This got me thinking: ‘maybe it’s a problem with Mac OS or FCP’. So I tried booting to Windows Vista and running a HD project in Premier – same thing happens, so apparently no problem with the software.
    I’m beginning to think that we’re going to have to go for a new capture card as the Blackmagic seems to have fallen at the first HD hurdle.
  • Kristian Lam
    October 7, 2008 at 10:57 am
    hi James
    Is the card in the top slot of your mac pro? Is the Expansion Slot Utility set to option number 2?
    regards
    Kristian Lam
    Blackmagic Design
  • James Fuller
    October 7, 2008 at 11:51 am
    FIXED!!!
    I love you!
    I had it in slot 2 to allow it to ‘breathe’ a bit. With the card in slot 4, if you have disks in all 4 bays of the Mac Pro, the DeckLink sits very close to the drives. It’s a while since I first installed the card, but I don’t remember instructions being so specific. Maybe this is something Blackmagic could consider revising? – although I seem to be the only one to have this problem…
    Thanks for the help though!
  • Kristian Lam
    October 7, 2008 at 1:42 pm
    Cool. Your Mac has PCIe slots with assignable lanes. In slot 2, it’s probably only running on x1 PCIe bandwidth which does not have enough bandwidth for 10- bit Uncompressed HD. You might want to just check the expansion slot utility and see if can assign more bandwidth to slot 2 if you really want to use that slot.
    regards
    Kristian Lam
    Blackmagic Design
  • Ryan Jenkins
    October 8, 2008 at 6:36 am
    Hi guys,
    i’m not sure if it’s the same problem but i’m have the same issue with PC and premiere pro using the BM’s Multibridge Pro. The only difference is after i render the clip the flickering stops, until i drop an effect back on the clip and then it starts again until i render it??
    Cheers
    Ryan.
  • Kristian Lam
    October 8, 2008 at 7:08 am
    Hi Ryan,
    Don’t think it’s the same thing. Sounds more like a field issue to me.
    What kind of format you working in?
    regards
    Kristian Lam
    Blackmagic Design
  • Ryan Jenkins
    October 10, 2008 at 12:27 am
    Hi Kristian,
    I seems to happen on all HD projects and even when the timeline isn’t playing.It’s like when a monitor is receiving a non sync signal, it flickers and clicks. All is normal once the clips are rendered. I mainly shoot and cut progressive.
    Cheers
    Ryan.
