Activity › Forums › Blackmagic Design › DeckLink Driver 5.5.1 and 6.6.4
  • DeckLink Driver 5.5.1 and 6.6.4
    Posted by Ketklao Kongpakdeepong on April 1, 2008 at 11:50 am
    I’m using DeckLink Extreme for a while. Recently I check Blackmagic Design website and found the driver section.
    My question is,
    What’s the different between 5.5.1 and 6.6.4?
    I know that newer should be better than the older one.
    But since my 5.5.1 is working well, I wonder that should I upgrade or not? I also working on some unfinish projects and afraid that if I decide to upgrade, they might be problem with my projects.
    So I’d like to know the different between 5.5.1 and 6.6.4 for decision making.
    If there’s nothing much or it’s something that I didn’t use / have problem. I might wait for a while.
    Thank you in advance
    Ketklao K.
    Ketklao Kongpakdeepong replied 18 years, 5 months ago 3 Members · 5 Replies
  • Del Chapple
    April 1, 2008 at 6:51 pm
    my experience with BM is that if it aint broke dont fix it!! new bm drivers often cause me headaches..
    del
    you cant hear my inner voice scream… can you..?
  • Ketklao Kongpakdeepong
    April 2, 2008 at 2:30 am
    Thank del, that’s what I think.
    But I also have problem with DV PAL capture which will lost a few frame for every clips. Does this fix in the later version?
  • Del Chapple
    April 2, 2008 at 2:37 pm
    I doubt that an update would fix that, but you can try it. when i’ve loaded bad BM drivers i’ve gotten serious vtr control issue’s etc. you can always downgrade the BM software if the new one doesn’t work. Dropped frames usually is a drive read/write problem. defrag your drive etc..
    del
  • Paul Provost
    April 5, 2008 at 5:30 pm
    watch out. see the thread above. user updated driver and it killed his card.
    Paul Provost
    http://www.postandbeam.tv
    April 10, 2008 at 8:15 am
    Thanks a lot Paul,
    If it’s real. It’s seem so frighten.
    BM guys should respond to that thread immediately.
    I’ll watch that thread.
    Thanx again.
