Activity › Forums › Adobe Premiere Pro › Decklink Card Questions
  • Decklink Card Questions
    Posted by Robertp on March 17, 2006 at 6:05 pm
    I’m looking at adding one of the Decklink cards to PPro 1.51 (currently with no video card, just monitoring by using a DAC from the DV out). I have a couple questions of people who have used the Decklink cards:
    1) Although they are intended as uncompressed I/O cards, what happens when you place a compressed clip on the timeline, such as a Qucktime with the animation codec. Currently, if I place a Quicktime clip in a DV sequence the PC will do the best it can to decode the Quicktime, and encode it to DV in realtime. I can usually get a single Quicktime clip to play full res, full frame in real time. If I install a Decklink card will it function in a similar way?
    2) Currently if the CPU can’t keep up with decoding/effects (and the preview setting is set to Automatic Quality), the image resolution will degrade gracefully while maintaining a full (or nearly full) frame rate. I’ve heard that the Canopus NX for SP video card (which I’m not considering) insists on displaying full resolution and full frame rate … if a frame needs to be skipped it simply stops. Will the Decklink cards degrade resolution gracefully to display a real time preview?
    Are Decklink users generally happy with the product? Any significant problems?
    Robert
    Robertp replied 20 years, 6 months ago 2 Members · 2 Replies
  • John Baum
    March 17, 2006 at 6:53 pm
    The Decklink card works like the canopus in that it will render anything not in its preferred codec and format. With a fast system I haven’t found this to be an issue. Then again, I spend more time in After Effects the PPro so I am use to waiting for preview renders.
    I have the DL Extreme since we mostly work from BetaSP. Overall I think the card works great. Tech support is very responsive to any problems and the drivers are updated often.
  • Robertp
    March 17, 2006 at 6:59 pm
    Thanks for your response!
    Just to be clear: If you place a clip on the timeline that is not in it’s preferred format, you see Nothing out of the card during playback for scrubbing until it’s rendered?
