Activity Forums Blackmagic Design Decklink Audio – Problem…
  • Decklink Audio – Problem…
    Posted by Chrome on July 18, 2005 at 4:45 pm
    I simply cannot get to the bottom of the following problem and I wondered if anyone else was having the same.
    I am recording high quality broadcast wav files on an Edirol R-4 at 24-bit 96Khz – playing them back on the Edirol they sound perfect. I then transfer them to my Mac (G5 2×2.5Ghz) via USB so the audio files are exact copies of the files I have been listening to on the Edirol. The stereo audio out from the Mac is via the Decklink Extreme into ch1+2 of my Yamaha 01x digital deck. However whenever I listen to them playing from the timeline of FCP they sound like sh*t; almost as if the speech is semi-composed of modulated white noise as part of the speech (nearest I can explain). If I play a speech MP3 from the web this way, it sounds like the people speaking are lisping or have a speech impediment.
    I know the 01x is fine as I use it for other recording purposes (i use it without the Mac) and the quality is perfect. I have reasonably high quality cables connecting the Decklink and 01x.
    There does not seem to be much I can change to configure the decklink card. Any ideas?
    Cheers,
    Chrome
    Jason Levy replied 21 years, 1 month ago 2 Members · 3 Replies
  • Jason Levy
    July 18, 2005 at 4:57 pm
    Just a wild guess but it sounds like a sample rate mismatch somewhere or perhaps a bit depth mismatch? is your 01 x expecting 24 bits?
    just a guess..
    jason
  • Chrome
    July 18, 2005 at 5:18 pm
    The output from the decklink and input to the 01X is analog so I think the bit resolution is irelevant. However you might have a point with the sample rate mismatch, perhaps I should copy the original files and convert them to 48Khz before editing in FCP. Hmmm…
    Cheers,
    Chrome
  • Jason Levy
    July 18, 2005 at 5:55 pm
    ah.. you are playing back 96 k files from a 48k sequence… I get it. I don’t find the “on the fly” conversion to be too solid except for a quick preview… perhaps that is your problem. Got a feeling that doing the conversion will help.
    good luck.
    Jason
