Activity Forums Blackmagic Design Decklink-AJA inferior incompatibility
  • Decklink-AJA inferior incompatibility
    Posted by Jaromir Pesr on October 15, 2007 at 6:47 pm
    (Modified, posted to AJA Xena board as well)
    Hello,
    we have several well running Decklink (most of all HD 4:4:4) workstations in our studio but now we were forced to build one with AJA Xena 2k PCI-X card (because of direct to DPX capture feature). I was not happy about this need but I have to say that this card is running as good as all of BM does.
    BUT:
    Because we need some backward (and forward) compatibility to share BM projects (in and out) we are running as well I tried to install Blackmagic software Codecs (v 4.9 seems to be the latest one) to be able to open or render BM files within AE or Premiere (forgot to say we are on PCs and running CS3 with AJA board). But now it seems that BM codecs kick AJA drivers some way… After installing everything seems to run great. I was able to open HD and SD BM footage in AJA Premiere project through AJA output and play it reel time, but after reboot there was just greenish drop-outs on AJA output instead of picture and it was not depending what type of footage is on Premiere timeline (AJA clip, BM clip, DV clip or even seq. of frames) After Effects AJA output seems to be unaffected. When I unistalled BM codecs everything rolled back to normal.
    Why the BM SOFTWARE codecs doing this? I thought it is just codec as any else? Isn’t it?
    Any thought?
    Thanks in advance
    Jaromir Pesr
    i/o post
    Prague
    Pentti Kakkori replied 18 years, 11 months ago 2 Members · 1 Reply
  • Pentti Kakkori
    October 16, 2007 at 7:01 am
    Have you tried with newer BM drivers, they should act as software codecs if you don’t have BM hardware installed?
