  • Posted by Oliver Peters on February 4, 2012 at 1:20 am
    Testing 10.0.3 with a Decklink card. Half-baked at best. I can see why Apple calls this a beta and only for monitoring. Dropped frames. Constantly flashes to black as FCP X is toggling states between skimming and playing the timeline. JKL timeline playback (especially at slow speeds) is useless if you are trying to view the external monitor. On the plus side, skimming works well through the external output. In general, color output is close to what I see on the viewer, though a slight gamma difference between the viewer and the output. That’s normal, but it tells me ColorSync is really no better than with FCP 7.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    David Roth weiss replied 14 years, 8 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    February 4, 2012 at 2:03 am
    I was noticing today while watching the Kona control panel (AJA, I know) that the frame buffer changes to YUV 8 (as in 8 bit) and then back to YUV 10 when clicking back to the finder.
    Needs work, for sure.
    Jeremy
  • Oliver Peters
    February 4, 2012 at 2:29 am
    There’s also no added pulldown in the Decklink control panel. With FCP 7 the 23.98->59.94i conversion occurs in the FCP software. So, with FCP X, you have to have monitors that support 24pfs if you are working on 23.98 projects.
    – Oliver
    Orlando, FL
  • David Roth weiss
    February 4, 2012 at 4:15 am
    Good reportage Oliver.
    I just reported above that Matrox drivers are coming soon. I suspect they may encounter the same issues in this release. But, who knows?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
    https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
