Activity Forums Apple Final Cut Pro Legacy decklink 1080i playout and downconvert to PAL – BLACK FRAMES and GLITCHES
  • decklink 1080i playout and downconvert to PAL – BLACK FRAMES and GLITCHES
    Posted by Peter Lee-jones on December 11, 2006 at 5:45 pm
    Big problems here.
    HD to SD downconvert to tape. Easysetup HD1080i 50
    I have a film 1.5 hours long. When I play it on the timeline it appears to be playing fine on the computer monitor. (hard to tell if it stuutters on the cinema display.
    When I try to master it to tape I get black drop out and black frames. The TC also slips and audio drops out.
    The errors occur every 1 to 2 minutes and are intermittent. When I play that part again the errors or on different frames.
    I have closed down the videomonitoring window and the desktop mirroring.
    When I try to render out the movie the file has dropout rendered into it! So I can’t even do the playout from a single qt file!
    Any clever ideas appreciated.
    Michael Gissing replied 19 years, 9 months ago 3 Members · 5 Replies
  • David Roth weiss
    December 11, 2006 at 6:36 pm
    Dr.,
    Not enough info provided, though it sounds like you’re dropping frames. . Is this uncompressed HD? What type of drive array do you have? Provide more details and I’m sure we’ll be able to help you.
    DRW
  • Peter Lee-jones
    December 11, 2006 at 10:01 pm
    The system is a QuadG5 with 2GB RAM. The raid is a 5TB Eonstor. Via ATTO SCSI.
    The decklink is connected to a DVW2000P Digibeta Deck. With SDI returning to the Decklink and RS422 control.
    The sequence is 1.5 hours long! it is mostly 1 track with only occasional dissolves and titles on three tracks. It is colour corrected throughout and the thus the whole track is rendered. there are 4 tracks of audio.
    Setting UNCOMPRESSED 10 bit quality 100 48khz 16 bit
    Frame size 1920×1080 HDTV 1080i(16:9)
    Device control HDTV 1080i 50
    output setting HDTV 1080i 25
    Desktop mirroring is off
    When I try to edit to tape, after about a minute the break up starts. It struggles on and then crashes the edit to tape.
    It seems to play the HD via SDI onto a HD monitor slightly better. But the downconversion keeps failing.
    I have tried reducing the memory allocation of FCP. I have tried printing small sections of the film.
    Many thanks.
  • David Roth weiss
    December 11, 2006 at 11:02 pm
    Pete,
    Well, it sounds like you have sufficient hardware for sure. Did you try mixdown in the render settings? Thats the only other thing I can think of.
    DRW
  • Peter Lee-jones
    December 11, 2006 at 11:39 pm
    It is the same even when delete the audio tracks
  • Michael Gissing
    December 12, 2006 at 7:54 am
    I assume you have the digi beta referenced to the same video ref as the Decklink card.
