Activity › Forums › Apple Final Cut Pro Legacy › Deck/Format Compability Question.
  • Deck/Format Compability Question.
    Posted by Justin Gray on August 18, 2006 at 2:31 pm
    My company is looking to move from our Avid to a new FCP suite. The primary deck we are capturing from is a JVC BR-HD50. We shoot with a JVC GY-HD100. Since most of our commercials are for broadcast at local TV and cable companies we are sending out SD materials for them. This means that we set the camera up to shoot in SD-60P rather than HD-30P. Using the above mentioned camera and deck, I am finding it possible to capture into FCP 5 in HD-30 but not SD-60. Is SD-60 no supported in Final Cut? If it is not, should I get a new deck to achieve an SD pruduct using the same camera? Thanks.
    Justin Gray replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
