Activity Forums AJA Video Systems Deck Rewinding problem while digitizing
  • Deck Rewinding problem while digitizing
    Posted by Greg Jones on May 17, 2005 at 2:29 pm
    I’m digitizing DVCPRO HD to a Lacie 800GB drive. I’ve done this before with no problem. I’m digitizing from a AJHD-130 (Grandfather of the AJ1200A) and it rewinds to the beginning of the tape for each clip after I’ve set up Batch Digitize. Has anyone else experienced this problem?
    Greg Jones
    D7,inc.
    Bob Zelin replied 21 years, 4 months ago 4 Members · 4 Replies
  • Walter Biscardi
    May 17, 2005 at 5:23 pm
    You mean after every clip it captures, the machine will rewind to the head? That is pretty strange. Are you using the Panasonic controls settings for machine control? That’s about the only thing I can think of.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Tony
    May 17, 2005 at 6:00 pm
    Is your timecode ascending or did you break timecode and mix higher and lower timecode hours?
    Tony Salgado
  • Greg Jones
    May 17, 2005 at 6:36 pm
    The timecode on the tapes are fine. I checked my settings in the Kona Preferences and they seem fine. It’s really weird. I’ve never encountered this problem before. Could it be a deck setting?
    Greg Jones
    D7,Inc.
  • Bob Zelin
    May 17, 2005 at 11:47 pm
    Kevin does not have this problem, and if you Time Code is ok (I’d check it again, as suggested in previous post), I’d ask Kevin if he changed anything.
    That is pretty strange. David Nixon is also using the HD-130 with no problems.
    Bob Zelin
