Activity › Forums › Avid Media Composer › deck never recognized
  • deck never recognized
    Posted by Angela Borg on June 11, 2008 at 10:50 pm
    I am trying to simply capture footage into Avid Xpress Pro 5.7, but I always encounter the issue of Avid not recognizing my deck. Currently I have a Sony HC1000 NTSC camcorder set up as a deck. I know it is set up correctly through the firewire port because both FCP and iMovie recognize it automatically and capture through it. After configuring Firewire through OHCI, Avid still sees no deck. What can I do to make Avid recognize my deck? I have also used a Sony GV D300 that is listed as a deck option in Avid, but Avid still does not recognize it. I appreciate any help.
    I am working on a MAC BookPro OSX 10.5.3
    Angela Borg replied 18 years, 3 months ago 2 Members · 4 Replies
  • Jon Zanone
    June 14, 2008 at 12:48 am
    The HC1000 is not listed on the supported devices list – my guess is that is the problem. Have you tried setting it up with the generic template?
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Angela Borg
    June 14, 2008 at 7:37 pm
    Yes, I have tried Generic deck settings. But the same problem happens even with a deck that is listed. Any other suggestions?
  • Jon Zanone
    June 15, 2008 at 6:02 pm
    Assuming you are controlling the deck via firewire, make sure you select ‘OHCI’ as the channel in the deck settings.
    Would it be safe to assume you’ve NEVER gotten control of a deck in Avid?
    Jon
  • Angela Borg
    June 16, 2008 at 7:26 pm
    I am not new to Avid. I have had decks configured before on other systems, but for some reason my Avid Xpress Pro is having difficulty. I am connecting through firewire and have OHCI set.
