Activity Forums Blackmagic Design Deck Link flicker problem
  • Deck Link flicker problem
    Posted by Anuradha Jayathilaka on June 14, 2008 at 4:13 pm
    Hi i have a black magic deck link pro.
    Im using windows xp with premire pro 2.
    The problem is,
    when i add an effect or change the speed of a clip the clip starts to flicker, which appears to be a field problem.
    I tryed changing the field options fot the clip and the interpolate field filter. I even reinstalled the drivers.
    Nothing has worked so far. I need urgent help.
    Close your eyes and think for a while.
    Alex Barwell replied 18 years, 2 months ago 4 Members · 5 Replies
  • Margus Voll
    June 14, 2008 at 5:41 pm
    Hi.
    What settings do you use with your time line DV or uncompressed?
    Margus
    https://iconstudios.eu
  • Anuradha Jayathilaka
    June 15, 2008 at 2:16 am
    im using 10bit uncompressed.
    i have a betacam deck and using component connections
  • Kristian Lam
    June 19, 2008 at 4:32 am
    What about DeckLink driver version?
    regards
    Kristian Lam
    Blackmagic Design
    June 19, 2008 at 2:28 pm
    im using the latest driver. i still cant find a way to correct this.
  • Alex Barwell
    July 12, 2008 at 11:25 am
    Are you rendering on the fly as this might be beyond performance of your machine or disk array. If the individual frames can be clicked through OK, you may need to play off a faster/cleaner disk set to get the delivery rate required.
