Activity Forums Blackmagic Design Deck control over long lengths
  • Deck control over long lengths
    Posted by Chris Torella on March 8, 2010 at 11:11 pm
    Hey all i wondering how large multi room facilities handle deck control to machine rooms.
    i want to share one digibeta with two rooms – (each with a miltibridge pro) i have an 422 AB switch – and i am wondering if there is a better solution then running a 100 ft RS422 cable to the 2nd room?
    is there a good Rs422- to Ethernet solution?
    thanks!
    chris
    Chris Torella replied 16 years, 6 months ago 2 Members · 2 Replies
  • Bob Zelin
    March 9, 2010 at 1:49 am
    I have been using ethernet cable for 10 years for RS422 control.
    It works fine, and 100′ for RS422 is NOTHING !
    you use RJ45-9 pin adaptors. You can get them from
    https://www.milestek.com
    and others.
    This is the wiring color code I use (there is no soldering – you just push the pins into the holes on the 9 pin) –
    1 Red
    2 Orange
    3 Black
    4 Green
    5 nothing
    6 Brown
    7 Blue
    8 Yellow
    9 Gray (or white)
    Bob Zelin
  • Chris Torella
    March 9, 2010 at 3:21 am
    thanks bob, appreciate it
    Chris Torella
    Pickerel Pie Entertainment
    10-26A 46th. Ave.
    Long Island City, NY, 11101
    718.606.9840 O
    718.606.9843 F
